Hi all! I know that this thread is almost a year old now, but I figured I would finally update with some listening impressions about the A150s compared to my ELACs. I guess I'll start off by saying that I have moved into listening solely to the A150s, whether studying at my desk or doing some more critical listening. This was partly due to switching around my amplifier situation to make A/Bing them harder, but I've found that I just enjoy how easy the A150s are to listen to, at any volume.
In the past almost year of ownership, I've listened to just about every genre, from country, to rap, to classic rock and even classical music, and the A150s still make me smile regardless of what is playing. Like
@onwardjames had said, the midrange really is where the magic happens to my ears with these when compared to my B6s. Bass response in terms of output might be a bit more for the ELACs, but the A150s truly play a tighter bass line, which I've come to appreciate. For the past few months, the ELACs have been sitting on my desk (really just as decorations
), and so I decided to hook them up again a few days ago. Then I realized why I had switched to the A150s in the first place - the B6s, although very easy to listen to and a great speaker overall, just seemed a little dull and lifeless in the higher frequencies, and the lack of a dedicated midrange made some songs a bit less enjoyable than they are with the A150s.
I also changed the setup of my listening space, finding a shallower shelf so that the A150s could be spaced a bit wider and also up against the wall. Not only did this improve the bass response quite a bit to my ears, but I was able to find the perfect sweet spot with great center imaging. Currently I'm running them using the highest Spotify streaming through a Shiit Modi 3 DAC, using an old Marantz SR7200 in direct mode as a Pre to a Sonance Sonamp 1250mkII. Very thrown-together setup for now, but I'll upgrade to a better pre eventually. The Sonance I have bridged to 100w/channel, and it is honestly one of the more robust amps I have, and it sounds great to my ears, even though it was made for distributed audio installs. My one gripe currently with my A150s is that the woofer I re-epoxied rattles a tiny bit when playing very bass heavy songs at very high volumes. I don't usually listen to them at such volumes, so it hasn't been a problem yet, but once I graduate this May I'll probably get it reconed since I plan to keep these for a long time. I was also lucky enough to stumble upon a pair of BA T1000s for free a couple months ago that just needed one pair of woofers, so that has been another fun time listening to those!
