New Thorens Reference Table
I will translate the article:
The icon is back
"Somebody has purchased the rights to use the brand"
Unlike Direct Drive systems (...) The high inertia of the platter is therefore efficiently utilized and helps to passively remain a constant velocity of the platter.
"We could have built a state of the art DD turntable but the audiophiles fear them so we are speaking nonsense in this part of the report"
A common disadvantage of belt-driven systems is the potential resonance of the platter, which is observed as wow and flutter. The rotational inertia of the platter forms together with the elasticity of the belt an oscillatory system. (...)The Thorens New Reference features an innovative and highly effective active damping system by Seismion.
"We could have built a state of the art DD or Idler-wheel turntable but, you know, no one in our target group would buy it, so we have to deal with this well-known problem of BD turntables by creating the most overengineered turntable suspension ever"
The complex kinematics of the Thiele TA01 combines the precise and rigid guidance of a pivoted tonearm with the advantages of a tangential tonearm. This design guides the cartridge with a maximum tracking error angle of 0.036 degrees across the record.
"All the problems of the Garrard Zero 100 tonearm for 100X the price"
The active vibration isolation is based on piezoelectric acceleration sensors with an extremely high sensitivity, and an all-linear electronic control circuit to generate unrivalled low noise- and distortion-free control forces. This sophisticated mechatronic system is based on so called Sky-Hook-Damping and isolates disturbances already below 1 Hz and reduces them to less than 1% (-40 dB) at frequencies of 10 Hz and above.
"We could have achieved this using only rubber o-rings and viscous silicone, as SME does in their best turntables, but we know that if we did just that, you would buy the SME instead"
Sarcasm aside, the Thorens is a very beautiful turntable.
EDIT:
@Mister Pig ,
at what point does someone become a "hater" ? Is there a percentage of things they love vs things they hate that categorizes them as a "hater"?
I happen to love most things audio
Although I stand by my original statement, however harsh it may have seemed, it was meant to be snarky and I was actually hoping to get a laugh out of some body.
Don’t like the looks of it but that’s probably a marketing thing dealing with competitors in the same price range….Using a 3 phase motor solves a number of issues and adds control….
I’m very pleased there’s research and development going on in the high end turntable world:thumbsup:
VR
Andy
Note that 3-phase motor belt-drive turntable with electronic generation of signals was already done on the EMT 928, year 1968.
Yes was well aware that a variety of EMTs used 3 phase motors….was just having a conversation with @BillWojo about using a 3 phase motor in a build and Bill pointed out:
“cheap a single phase inverter for a small 3 ph motor will do the same AND you can set the frequency! And so much more! Some have thepossibility of multiple preset speeds and all have accel and decel adjustments.”
That proves that great minds think alike, or copy one another :rflmao:
VR
Andy
They lost me at "inertia", it's "momentum" in physics.
