New Thorens TD 145 Arrived!
Right. But would the extra weight of the weight cause a speed error?
BTW, I strobed it, and it's only just slightly fast. But my ears can hear it, so it's bugging me a bit. Hopefully the new belt will cure this.
I'd be more concerned with the impact of a heavy weight on the suspension and the bearing. Its impact on speed is probably small. I'd think the belt would solve the speed issues.
yeah, I might just ditch the weight. I wonder how much of that is just snake oil anyway.
Mine runs a bit fast too, but now that I got my direct drive table setup, I'm not too worried. I'll eventually get a new belt as well.
Did the alignment, antiskate, tracking force and vertical tracking angle seem pretty close?
The only issue I have is that the tonearm doesn't seem to want to stay in the tonearm rest very well. Breathe on it, and it moves out of the clip. Is there a remedy for this?
Same problem with mine. It doesn't grab very well at all. I leave the cue up when the arm is in the rest, it holds it against the top and helps to keep it in position.
I checked everything before running, and it was pretty good out of the box. I just had to adjust the tracking force. That was it.
The weight will put a bit more on the bearing, a rounded ball on the end of the spindle holding up the platter. They are not snake oil but the center weight is harder to hear the improvement compared to using both the center and peripheral weight. That combo made a big difference when I was using them.
The weight is not contributing to the speed issue. You have solved your speed issue with a new part, installed when it arrives. Read the manual on how to use the new belt.
Some folks can be really bothered by a very slight speed inaccuracy. Best to get gear that runs the right speed and that belt will solve the problem.
Did you clean the spindle well out and relube it? Of course there are more steps if you want to go there, new thrust plate (small disc put in the bottom of the well. Not needed if your unit is in good shape.
Once you roll over to www.theanalogdept.com> Thorens Dept. you will see on page one a 124 platter and support spindle diagram.
But you are interested in the TD-160 Dept to look over the maintenance, upgrades and tuning information. Good to learn before you dive in. Read over the pages and maybe put a bit more into the belt change to make the unit like new for you. Between now and belt arrival enjoy the tunes and do your research to see if you care to upgrade you machine a bit or do some routine maintenance on it.
Thanks. Will do!
The TD-160 Super came from the public and magazine tweaks being made to the TD-160. Sound deadening here and there, thick bottom instead of a piece of hardboard and other things. Thorens said, Hey that does make it better, we can build that and charge a bit more for it. I don't know how far along the upgrade path the 145 sits so that's up to you to see if your machine has the goods or needs em. Remember, folks have been and are still using TD models that have never been tuned, oiled, upgraded or whatever and many of them are happy. You can do what you want, listen for a while then do a winter project and see if you enjoy the difference or throw it all into the mix right now. Enjoy the journey.
Gonna piggy-back on this thread because by coincidence my new TD165 arrived yesterday and I'm already hard at work researching everywhere and trying to source minor parts. Unlike the OP I was a bottom feeder and got mine on the cheap. First order of business is to order a cartridge so I can figure out if it even puts sound out. Considering the A-T
VM520EB atm. Then the anti-skate apparatus probably, which is as weird as anything I've seen in awhile. The seller advised me to consider a Grace 707 but I really like the Thorens headshell design so I want to keep that if it's practical to do so. If I can replace the arm with a new Thorens arm, though, that might be an attractive option.
Question if I may: how can I determine which version I have? Mk1 or Mk2 etc.
This has implications w/r/t tonearm mass and hence cartridge compliance.
Here's the number tag if it'll help. TIA
Heck I'll even throw in a pic of the thing, because pics are fun.
I'll also have the pleasure of building a new plinth, or veneering the one here.
Because I had no idea any of them were vinyl wrap.
Doesn't it actually say so on the product name? Yours looks like a MKI, in that case.
Thanks, that's what I'm thinking, though I haven't been able to confirm.
Seems like the MkII has rear hinges, inter alia. Mine are on the side.
Have read dozens of threads on the topic since last night, and this one came awfully close to supplying the information I'm seeking, but still no cigar. Itching to get a cart that'll just work for now, then on to really improving things.
This photo appears to settle it, just as you indicated. Man this looks nice!
Apologies to the OP for waylaying the thread! Yours is definitely nicer than mine.
@Archguy
Yes the 165 came with a removable headshell and the -II and -III versions had removable arm wands.
I would get the manual for that table the TD-165 and follow the instructions on setting up a cartridge, anti-skate being one step. Try to decipher the intent of Thorens when moving the weight on both the hook and the pivot point grooves. manual is on theanalogdept and probably other sites.
If the model number isn't followed by a mark - it's a mark 1. Another tell tale sign is the tonearm. If it got a couple of rods for the weight on string anti-skate - it's a TP-11. If it got a dial for the magnetic AS, it's a TP-16. If it's the classic TP-60 flat wide headshell - it's a Mk-I. If it's a two part tonearm, it's not a Mk-I but rather one of the II, III or later with the TP-62 or TP-63 wands. The last image shows a TP-62 wand on a TP-16 Mk-II tonearm with the silver knob for the magnetic AS and obviously, no rods.
