I'd love to hear that stylus on my AT450E cartridge.Look at the cantilever and stylus tip on this puppy...it is narrower than the line it should cover on my protractor !!!
If you're a bit worried about breaking it, get a hold of the lesser stylli in the same
family for general listening, like the AT130E or AT120E. Neither will break the bank
and will give you a different sound to enjoy.
James H
The overall price for this cart has dropped on the auction site. I wonder why...:scratch2:
And now, after 1293 hours of usage on clean records and dry brushing the stylus every 1/2 lp, I have replaced my #2 atn150mlx stylus.
I was playing the Na Na Na track on my brand new The Knife - Silent Shout double lp the other night when I heard a slight but obvious uniform distortion in the high frequency vocals and music.
So I whipped out my sl-b100 / at92ecd and sl-qx300 / at3472ml combos to compare, and sure enough the track sounded fine; no distortion.
Aw man.
So tonight I swapped out my #2 atn150mlx stylus with my #3 atn150mlx stylus - sweating bullets here - and performed the usual setup and hfn-002 test record checks. I had to use my Shure stylus gauge because my digital one died (no suprise).
And now the Na Na Na track as well as the rest of the album sounds perfect and better than the cd except for the slight lp concentricity issues.
I don’t want to believe it, but no matter how clean I keep my records the styli diamonds do not last forever.
Thank you for that usage and life report.
I run 2 of my AT440MLa bodies with the ATN150MLX stylus (the gold cantilever version), and they are simply awesome. However, I can't decide if its better then the ATN150Sa (shibata). At any rate, if you have the AT440ML body, both of these stylus assemblies will fit and yes, in a micro second, you can tell its better then the stock ATN440MLa micro line stylus.
I am slowly replacing all of the old with the new.
Do you know if an ATN 12S Shibata stylus compatible with an at440mla cartridge? I bought the stylus a couple years back and and just got a great deal on the at440mla cartridge. I am hoping that the stylus will fit the new cartridge.
I have its predecessor, ML-AT150/OCC. Anyone know it? Coils dead but stylus new original.
Should I look for the original body? Sonically worth the dollars? Will the stylus fit other ATs?
