New tube amp
hogdaddy
AK Subscriber
OK its new to me anyways. The local thrift had 70% off on this and I got it for $13.18 w/tax. :banana:
Its from a VoM model # 582 console.
It is missing 1 6AQ5 tube and there are no speakers.
I saw another thread here on AK where another member made a stand alone amp with this same unit and I think I may attempt to do the same.
Also from my research here, this is the same amp as the VM 1404
Here are some pics.
Here's a few more.
Note it says Realistic on the speaker switch.
I have the knobs I took them off to clean and they look like new now.
Anyone have a shematic for this?
I don't see a line fuse - you DEFINITELY should add one. Caps are ceramic, won't be leaky. Electrolytic cans are always suspect, though. I can supply a schematic, and might be able to spare a few 6AQ5s (have a few hundred...)
Where do I put a line fuse and what size/type is best?
Sorry I am a novice here.
So I only may need to replace the 3 aluminum cans is all? Cool! :thmbsp: I see where another AK'er replaced them with individual caps underneath the chasis.
http://www.audiokarma.org/forums/showthread.php?t=359575 That may be something I could do easliy.
I am thinking this will be a good first tube amp for me.
PM me with schematics please.
The one VOM 6AQ5 amp I heard, was absolutely amazing. Some of the nicest bass response around. This amp is VERY worthy of a complete overhaul and update.:music:
The realistic speaker switch was not stock, but someone's attempt to have speaker versatility.
Of course you know that realistic is radio shack.
Well I picked up another 6AQ5 tube and input a tuner with some cheap Bose bookshelf speakers and I am getting no sound whatsoever. :sigh:.
Too bad I don't have access to a tube tester.
I bought the missing tube from an electronics repair shop and I brought all the tubes with me in hopes they had a tester. They didn't. :thumbsdn:
The filter caps don't appear to be leaking either but I guess they could still be bad.
The thing that worries me is maybe people tried pluggin it up at the thrift w/o a speaker load on it. I don't know where to begin to troubleshoot.
Now that you mention it, it does look like a cheesy attempt to add a switch.
If you have a test meter, put the negative probe on the chassis somewhere, and the positive probe to pin 3 of the 6CA4. Make sure your meter is set for DC volts 300 & up and check to make sure you are getting 250-350 volts. If so, the 6CA4 is good and putting out voltage to the amp.
Also, use speakers straight to the speaker output plugs in the back of the unit.
A filter capacitor that is open but not shorted will cause hum through the speakers. A shorted filter capacitor will cause arcing in the 6CA4 and/or smoke, so I don't think you have a capacitor problem with no sound.
Also, looking at your pictures, I can't tell if the green wires on both output transformers are going to the rear speaker plugs. You can wire the positive of each speaker to the green wires coming out of the transformers, and the negative wires of the speakers to the chassis.
Edit: OK I got some new battery's. I am getting 318 volts here now and when I had the probe on #3 I heard a hiss from speaker.
Yes it is the green wire. I am using 1 original speaker plug atm but was wondering about other ways so I can get stereo.
Well, stereo is sound seperation and you have a stereo amplifier designed to drive two seperate speakers with two seperate inputs.
Without a schematic, I am only guessing but yes, you should have at least a couple of hundred volts at pin 3 of the 6CA4. 14 volts is definitely a problem.
Without the 6CA4 in its socket, measure AC volts at pins 1 & 7. It should be something like 600 or 700 volts between the two. Now, if you plug in the 6CA4, you should be getting 250 - 350 volts DC at pin 3.
Do you hear anything from the speaker? crackle, hiss, anything? The next thing I would check would be those 3 grey brick resistors on the filter capacitor coming from the rectifier.
Ok I will need to remove at least 1 lead on the resistors right?, and to test will I have to discharge the multi filter capacitor first?
I have never discharged any caps before so I guess I need to reseach it some.
I just picked up a VoM console and it has the exact speaker switch built in to the back, except it says Olson Electronics and it was bypassed.
BTW-this is my first post.
Regards,
Phil
No sound can be several different scenarios. bad or open power resistor, Rectifier, faulty wiring, faulty ground, output transformer(s), tubes, and last but not least, operator error - :D
Remove one leg to test resistors. Personally, when I discharge a capacitor, I just short the positive part of the can to ground with a screwdriver. I don't buy into that it will damage the capacitor as I am only doing it maybe two or three times at the most, but I certainly believe it can be damaged if you do it many many times.
Thanks for the help it looks like this may be a good learning experience here (or a catastrophe).
I am gonna try and replace tubes first and see if that helps.
Next if that don't work I will try and test resistors and possibly others.
I also may attempt to replace the filter caps.
Wish me luck I am gonna need it. :yes:
The more I look at this tt the more I want to try and get this console back working. Imho it is a nice looking changer and it was working also. Well it did spin and seemed to be working ok.
