So, I just put together the Tubes4Hifi PH16 phonopre. This is the 2nd kit I have ever built. The 1st was the SP14 preamp. It came out great and sounds fantastic. The Ph16 is working great, too. Sounds fantastic. The only small issue I have is a little hum with the Sp14 gain controls maxed and the volume control at about 2:00. It doesn't interfere with the music while playing records on it. I'm thinking of trying to lower the hum as much as i can. I'm a complete newb on tube stuff. I'm thinking of redoing some of the wiring, shortening it as much as possible and rerouting it. I have already plugged everything into one outet, swapped interconnects around, and put shorting plugs into the phono input jacks. Moved the wires around gently with two chopsticks,but no change. I have some pics of the build, if there is something I should do I would appreciate the feedback.
