Well, so far I do actually like it. I've been yelled at from the excessive bass coming from my room a couple times now actually, I had to turn the loudness mode off, and turn the bass from +14 to +6. It does put out a lot of bass.
But the hissing is so annoying, but I think that might be the tubes.. My Fisher 800c has a hiss too, but only when turned up all the way. It honestly seems like the tubes are full gain constantly, and the volume is done digitally, so the hiss is constant.. I'm watching the new movie "Alice in Wonderland" on it, and the symphony music doesn't sound that bad actually, but with all the quietness in the film, the hiss rears it's head.. But luckily does NOT get louder when the volume is turned up. Also, I find that when the volume is turned to zero, it auto mutes, and the mute function actually turns the relays off, thus eliminating that hiss.
Still burning in though.. The AUX/USB input is trash though, you can hear a faint "beep beep beep beep", which is the USB "tx" lines, trying to detect a USB device being inserted, which may be a part of the hearing the cooling fans DC motor in all inputs (next to the hiss, a high pitched whine). So probably is fixable by means of a grounding-mod..
The transformer is what stands out to me. It's a toroid, as mentioned, and I've not seen one in any cheap amp.. But 2000 watts? Yea right. 600 watts RMS? Yea right.
However, I have found that the EQ spectrum analyzer, is NOT a spectrum analyzer. It is just an oscilloscope. Because when I send it a 20Hz sine wave, it sweeps from right to left, not just in the left side. So, it's an oscilloscope, NOT a spectrum analyzer. Besides, the analyzer is marked in frequencies, which "would" make sense if it WERE an analyzer, but it's also marked SL, FL, C, FR, SR, SW. Know what that means? Surround Left, Front Left, etc, which this amp is NOT surround sound. But under a flashlight, reveals Pro Logic and DTS digits on the VFD, of which are not connected to the mainboard. Just a re-used VFD.
