Looking for info/advice to help me decide which way to go on two tables I’m looking at. Currently running my first table, a Sansui SR232. It’s been a good tt but I’m gifting it to a relative and am ready to upgrade. I want new because life is t allowing much extra time to tinker on an older one at this time (although I know there are great vintage ones).
Two considerations are:
Music Hall Mark1 - ($300)
The world's largest online retailer of high-end audio, audiophile music, and accessories. We specialize in vinyl records and turntables.
www.musicdirect.com
Speeds: 33.3 / 45 RPM
Speed variance: +/- 0.9%
Wow and flutter: +/- 0.2%
Effective Tonearm (aluminum)-Length: 218.5 mm (8.6")
Effective Tonearm-Mass: 9.0 g
Overhang: 18.5 mm
Output: RCA Phono
Power Supply: 15V/ 0-0.8A DC
Power consumption: < 0.3 W (stand by)
Dimensions (WHD): 16.3" x 4.6" x 12.6"
Weight: 16.5 lbs.
Accessories: Audio cable, power supply, lid
Music Hall MMF 2.3 - ($450)
MMF-2.3 TurntableThe music hall mmf-2.3 turntable is a 2-speed belt driven audiophile turntable at a budget price. Focus on ComponentsConstructed using high quality components, the mmf-2.3 has been simplified to focus on the critical components: bearing, motor, and tonearm.The Complete...
www.safeandsoundhq.com
power supply 15V / 0-0.8mA DC
universal power supply
power connection 100 240 Volt
50 or 60 Hz
standby power consumption < 1 W
speeds 33 1/3 rpm
(manual change to 45 rpm)
wow and flutter 0.10 %
speed deviation 0.80%
rumble max > 68 db
effective tonearm (carbon) length 8.6 in. (218.5 mm)
effective arm mass 7.0 g
overhang 18.5 mm
product dimensions w17" x d13" x h4.5"
weight 17 lbs. pkg.
So, is 2.3 worth the extra $150 in y’all’s opinion? The 2.3 is stretching my budget to the max. But I’m willing to pull the trigger on it if it really is that much better of a table. They both share same plinth, motor and both have VTA. Biggest difference I see is the 2.3 has the carbon tone arm vs. aluminum on the Mark 1. While the carbon arm would reduce resonance (and look purdy), would it limit my options on carts due to its low mass?
FWIW, the others that I’m considering are the Fluance RT 82, Uturn Orbit and Project T1.
Appreciate the advice in advance and happy weekend!!
