I saw your interesting posts over there. How do you explain that all the Rs, Ls ,and Cs in the speaker's crossover have no effect on the sound but differences between op-amps are audible? It seems unlikely...
There was no discussion about surround sound. Plus too much challenge again got me banned even that I provided references to back it up. All I got after that was requests to put it in different wording, nit-picking and disrespect that I dished back or ignored. Yeah that forum is a cult with mislead minions mostly. Not sad as it was expected that the admin couldn't handle the truth.
But if you are talking about surround sound the effect has to come from the Audio Visual Receiver itself plus the original source to create the surround sound effect (DVD/Blue Ray usually). That's another point why AVR is not the best for Bi Amping and doesn't work. We are still talking about 2.0/2.1 systems. So taking front signal and rear signal that are different and asking the speaker to do two different things simultaneously won't have a good result. That should be logical.
But two separate Stereo Amps with volume knob the same signal Left and Right used to power the High and Low separate you get more power and the control between the woofers and Tweeters separate by controlling the power. Crossover balances the power between High and Low but by powering the High and Low separate you now have the control. You controlling the power between high and Low the crossover loses lot of it intended function. Yes it is still there but not doing much.
If you ask a question from Google you get fairly good answer. "Benefits of passive amping?
Passive bi-amping provides several potential benefits, primarily by delivering more power and control to speakers that have separate inputs for high and low frequencies.
Crutchfield +1
The main benefits include:
- Increased Power and Headroom: By using a separate amplifier channel for each speaker section (woofer and tweeter), you are effectively providing more total power to each driver. This results in greater dynamic range and more headroom, which can lead to a cleaner and fuller sound, especially during demanding musical passages.
- Better Driver Control and Tighter Bass: The extra power dedicated to the low-frequency driver can result in tighter, more controlled bass response and more impactful low notes.
- Reduced Intermodulation Distortion: By separating the amplification for different frequency ranges, the low-frequency signals are less likely to modulate or interfere with the high-frequency signals, which helps to reduce distortion and "muddy" sound.
- Improved Clarity and Soundstage: Many listeners report increased clarity, better definition, and a wider, more open soundstage, as the separation of signals allows for a more accurate placement of instruments within the stereo image.
- Easier Load for Amplifiers: The speaker presents a less complex and "easier" electrical load to each amplifier because each amp only has to deal with a limited frequency band. This can reduce stress on the amplifiers.
- Cost-Effective Upgrade Path: If you already own a compatible receiver or a second amplifier, passive bi-amping can be a relatively inexpensive way to improve sound quality compared to upgrading the main amplifier or moving to a more complex active system with external crossovers.
Ultimately, the perceived benefits can vary depending on your specific equipment and listening environment, but many audiophiles find it to be a worthwhile improvement.
Op Amps we have been talking about Class D Amps all along where the circuitry is simple. If we were talking about expensive A/AB Amps with over the top complicated circuitries you would be right the audible difference would be minimal and you most likely wouldn't hear the difference. But Class D is very simple where changing something small can make a huge difference to bad or worse or brilliance. That's why there are popping new vendors selling specially made Op Amps that can cost as much as the Amp itself. Yes there is a big difference. But here is the catch that gets halve of the audiophiles nickers in a knot. Their hearing is not good enough. These people only rely on numbers because their hearing is poor and now we are back into the circuitry design where you can and can't. I personally don't claim to have a super human hearing but it is good enough to spot differences even on youtube blind tests. Of course not all because some just are very very poor quality and some Op Amps are so close that it is more of a guess from a gut feeling. But if you would ask to spot differences between ne5532, opa1612 or Sparkos Op Amps you should be able to hear it with a good difference even on moderate youtube comparison.
Again ask a question. "why different Op amps sound different on Class D amps and not on class A/AB amps?"
Op-amps in Class D amps have a higher impact on sound because they operate within the critical, high-gain feedback loop that shapes the pulse-width modulation (PWM) and manages output filter interaction, whereas in Class A/AB amps, they often only act as pre-gain stages with less impact on the final output.
YouTube +1
Key Reasons for the Difference:
- Feedback Loop Sensitivity: In many Class D designs, the input op-amp is directly involved in the feedback loop that controls the switching mechanism. A different op-amp changes the loop gain and speed, significantly affecting the reconstruction of the audio signal.
- Interaction with Output Filter: Class D amps use an output inductor/capacitor filter. The op-amp's characteristics influence how the amplifier handles the impedance load of the speaker, which can lead to high-frequency variations (brightness or harshness) depending on the chip used.
- Input Stage Role: In Class A/AB amplifiers, the input stage (op-amp) is generally just a pre-amplifier stage. While it sets the input impedance, it is less critical to the final output signal's integrity compared to the switching modulator of a Class D amplifier.
- Modern Class D Design: In older or budget Class D designs, the lack of post-filter feedback made them more sensitive to the op-amp choice. Newer, high-end designs (like Purifi) are less susceptible to these changes.
Ooberpad +4
Note: While op-amps often make a more noticeable, or "tunable" difference in Class D, the perception of better sound quality is highly subjective.
StereoNET +2
Hope that helps.
