Hi, I've started refoaming a pair of Kirksaeter speakers that both need new woofer surrounds and I'm having trouble getting rid of the squeaky rubbing sound when I gently depress the woofer around the cone. By slightly resetting the surround I reduced the squeak/rubbing but didnt eliminate it. Now, with the glue having set, I played music at a low volume but the bass is muddy and it's obvious that I didn't do this right.
I did not use 'the battery method' because I didn't understand it (I don't know anything about electrical systems). The way people described it, installing and tweaking the surround by hand sounded simple so that's what I did.
Any advice on what I did wrong or what I should do instead? If it's the battery method can someone point me toward an explanation that's pitched to beginners and hopefully does not involve buying electrical equipment?
If I don't get this right, is there someone in NYC (I'm in Brooklyn) who would do this for me for a reasonable rate? I saw Anologique mentioned here and just sent them an inquiry. Anyone else who does this work reasonably or, better from my perspective, could just show me how to do it?
Thank you very much for any advice?
