grillebilly
Empty Head
I shim each and every one because i know it perfectly centers the VC. It also makes gluing easier because you can lift the cone away from the basket while gluing. All the reasons stated above are more reasons to shim. Using a test tone IMO is also a good way if you decide shimming is too much of a hassle. One or the other is a requirement if you want to assure a good job each and every time.
