You could put the equalizer between the 101b and the 202.
Is this the model?i'm going to be getting ahold of a sansui se-9 compu-equalizer
thanks for info and yes thats the model.i have to be honest i know very little about stereo stuff.so to be honest what you said about adjusted frequencys etc.i have no idea what any of that means.Is this the model?
http://audio-database.com/SANSUI/etc/se-9-e.html
An equalizer with the lowest adjusted frequency 80 Hz will not allow to manage the most critical frequency band for market loudspeaker systems: neither compensate the lack of acoustic output in 30…60 Hz band, nor correct the room acoustics in this very important frequency band.
thanks,it was easy way back when(1979) how to hookup amp to preamp/equalizer.could you elaborate on what gets hooked up to what etc?what in's to out's etc?thanks in advance
thanks for the info,let me run a few things by you(if you don't mind)first thing i don't have my tape deck hooked up anymore.i have a cd player,turntable,a receiver hooked up to preamp/equalizer&seperate amp.i haven't got sansui equalizer from my nephew yet.in your drawing i'm thinking the reciever would be like my preamp/equalizer&?do i need to hook my tape deck up again to get things working right once i get the new equalizer?thanksThere you go.
thanks for info,why would they make it like that(tape 2)?to me it looks like the rca ends are missing.so those 2 ends are called 1/4"trs jacks?would it do any good for me to look for adapters?if so,where should i look and exactly what to look for?thanksTape 2 looks like 1/4" TRS jacks on there so you can't use that without adapters.
hook the Tape1 output of the preamp into the input on the equilizer. Then connect the EQ's output into the preamp's Tape2 input. In order to make the EQ effective, you have to select an input on the preamp that you want to output to the tape (EQ). Then engage tape2 (monitor) to hear the sound that is being altered by the EQ.
Why would it matter which way it is hooked up with the spectrum display? I believe it should work either way as long as it is getting signal, which it is. EQ gets signal means spectrum display works. I have hooked my EQ up to both the tape out on the 7140 and also the pre out and in both cases the display works just fine.
