They have been altered. They could be working fine, or not. In any case, without extensive documentation of all the changes, and if you are not likely to work on them yourself, then, frankly, I would not buy them. If you ever run into problems with them, you'd have to pay someone to try to reverse-engineer the changes and figure out what to do. IMO, a pair like this is best for someone who is prepared to either dive in and sort them out, or tear them down and rebuild them to the original configuration. You'd need a decent amount of technical knowledge to figure out how to relate the changes to the
original Dynaco documentation, and even then you'd be pretty much on your own trying to figure out what to do next, again, in the event of problems.
IMO, especially for someone new to tubes and new to Dynaco, it makes a lot more sense to just buy a new plug-and-play pair from
dynakitparts.com. At this moment, I think the Mark III might be out of stock. If you'd rather not wait, consider a pair of Mark IV monobocks
https://www.dynakitparts.com/shop/mark-iv-kit-120-vac/ Again, even though they say they are kits, I believe they can be purchased either kit or fully assembled, plug-and-play. BTW, I have no business affiliation with
dynakitparts.com.
