A tweak or two for the jewels.
I found the brightness from the unit's bulbs to be a bit too bright on the replacement jewels. I know they are only reproductions and not the originals ..... the original jewels had a certain "diamond cut" that would mellow the light so as not to be too bright.
Also, I found that the individual light bulbs that were supposed to feed light to a specific jewel somewhat dispersed the light causing the jewel next to it to be semi-lit.
No problem....
Tweaked as follows, with no harm done to any part of the unit.
Before any tweaking, jewels just too bright:
Minor tweak here. Wrapped some electrical tape around the light bulb tubes, enough tape to make contact with the faceplate so as to make a "seal". No light would escape.
Next, I needed something that would absorb and diffract the light entering the jewel:
Make little balls of Scotch Tape and stuff them into the jewels:
Difference is quite apparent. The last jewel (on the extreme right) has yet to be stuffed, and jewel "C" is indeed stuffed but not lit:
It ain't over yet...
Sorry for the sad pics, but I promise better ones once this puppy is up-to-par!
Stay tuned.
Thanks!
