Most of the Sansui/Marantz hype is just that.
I was a Technics fanboy during the 80's and most of the 90's, so they DO exist.
Now I'm a Sony/Pioneer guy, but I'd absolutely have back my SA GX-500.
@SVI2004A Howdy! Oh dang, so it seems no attempt at connecting to my R210 as preamp?
tape loop option won't work to connect a power amp either, you need a pre out for that unless as I stated earlier the power amp has gain controls. But keep in mind this will also bypass all tone controls etc along with the volume control.@Grenadeslio @coonmanx
@sqlsavior Thanks.
So I gather try out the Tape Loops option to the 2nd unit vs the EQ Ins (not a pre).
I have read Both opinions that the Pre-amp colors most of the sound quality and also that the Power amp colors most of the sound quality?
Open ended debate about sound preference coloring or is there some actual logic and reason to be shared here, please?
My preference would be to use the beastly V6Xx as the power amp and to use the other unit (maybe the R210) as the Control volume selector etc. Is it possible to use the R210 as a Pre and still use its Tuner, too?
Conventional wisdom suggests that transparency is especially important in a preamp/line stage, because any coloration or veiling will apply to every source. Taming shrill speakers with a dull preamp my be fine - until you change speakers. If you want to wear rose-colored glasses, however, the preamp would be the component to put them on. IME, power amps all sound different, too, and of course they affect every source as well. Conventional wisdom also suggests matching the power amp to the speakers, but there is another school of thought that a really good amplifier is what separates real hi-fi from pretending, and that such should be able to drive any speaker, with the only question being whether it goes loud enough, cleanly. But these days, even chip amps can sound really good.I have read Both opinions that the Pre-amp colors most of the sound quality and also that the Power amp colors most of the sound quality?
