I bought Nikko Beta 40 pre amp and the seller said it is working. But its not, but i dont want send it back since its hard to find.
I think the relay is not clicking.
Trying to isolate, is this what i do is correct?
I pull the bridge rectifier D801 and D802 except to the relay which is D803.
I did check all transistor and caps and resistor, so far its looks good reading.
What i already replaced:
C901 new 100uF, old was reading 80uF
C826 new 33uF , old was reading 48uF
Q901 Transistor 2SC1845 to FairChild C1845.
But im still confused, the relay still not clicking.
This is protection relay, am i right?
I did pull the relay to check it doesnt has clicking sound? Looks like big IC. Supply it with 12v to the coil symbol and using DMM with beep mode it is working.
When power on, the relay coil both pin is 15.9v. After delay around 5 seconds, they both drop to 12.2v
Is it normal?
And in transistor Q901 SC1845 pins:
Here is the schematic.
Please help, 4 days cannot find the problem. I will post any information needed.
Thank you so much.
UPDATE 2024.08.05
As i promised to give information after full recap and cleaning back of the pcb, hope will help future owner with same problem.
My solution was replace:
Here is the final DMM reading:
Please note:
RED is previous reading
BLUE is the final working condition
Muting relay clicks around 8 secs.
Q901 Collector reading is decreasing When powered 14.4v, after 8 secs around 6.1v then until 0.95v
Thank you for AK members for helping me.
Is it normal?
| PIN | Power ON | Delay 5 secs |
| RELAY RY901 | ||
| COIL 1 | 15.9v | 12.3v |
| COIL 2 | 15.9v | 12.2v |
| Q901 SC1845 | ||
| E | 0.0v | 0.0v |
| C | 15.9v | 8.3v |
| B | -1v | 0.66v |
Thank you so much.
UPDATE 2024.08.05
| Parts | Service Manual | Physical | Replace |
| D804 | 1S2076A | 1S2076A | Fairchild 1N4148 |
| D902 | 1S2076A | 1S2076A | Fairchild 1N4148 |
| Q901 | 2SC1845 | 2SC1845 | Fairchild C1845 |
Please note:
