Amazing work.
what are the sonic results ?
Good question
I had the possibility to make a comparison with 3 tuners, Sony ST-J88, audiolab 8000T and rare naim NAT-01. (I was unable to make a comparative test with the magnum dynalab FT101 Etude).
About the 3 tuners, my preference was NAT-01, that most seduced me.
The first impact, the naim is more musical, the bass is more extensive but a little confusing and also has a greater silence. The NIKKO the bass is not as extensive as the naim, it also had two "defects",
the RF gain was high, sometimes saturated, and d\ont have the same silence as the naim. After several tests, for two weeks, these problems were solved.
The gain of the RF amplifier, (BF981), has been reduced. The IF amplifier, also a small change in signal gain.
An improvement was made to the power supply for IC, LA1235.
The gain of the original circuit (MPX decoder)of nikko gamma 30 is about (4.7X .... 13.44dB), it was changed to 1.41X .... 3dB. The output impedance is now also lower than the original circuit.
This update resulted in a greater silence in the music, more neutral, very fast. The sound is now of the type (recording studio sound).
Finally, to compensate for the limitation of low frequencies (due to the output capacitors of conrad johnson C-JD, having only 1uF). After many tests with various models and manufacturers of electrolytic capacitors and tantalum
A 22uF / 25V tantalum capacitor was added to each channel in parallel with the C-JD capacitors). This combination works very well here. See pic.03
Now I prefer Nikko, he doesn't have the naim musicality, but he has a studio sound, he is more real, more 3D, more neutral and has better bass performance.
During the day the naim is more silence, but at night the nikko performs better.
It was an update that was a little expensive, but with Spectral amplification Pre/Power I am very happy with the final result, especially when is night .....
jon
