Background:
I have some Marantz MA500 mono amps that I am looking at modding a bit. They are made to be able to be bridged and have a signal inverting circuit that uses a NJM4558DD to do the work to output an inverted signal to the second amp in the pair. The rail voltages are +15v & -15.3v. There is a 10µF/16v stabilizing/local filter cap on each power rail.
The NJM4558 is not a beloved op-amp and I have a lot of NJM5532DD and NJM2068DD parts on hand, so I am considering replacing the 4558 with one of these op-amps. I plan on upping the local filter/stabilization caps to 47µF/35v with a 0.1µF/50v in parallel.
I am looking for opinions from members that have experience with both the 5532 and 2068 as to which they prefer and/or would use in this specific case that I am asking about.
Note that I am aware that there are newer op-amps out there that might be superior to my choices. These are the parts that I have on hand. I am not interested in starting a general op-amp debate. My subject and question is quite limited and defined.
Thanks in advance for any experienced and informed replies.
Cheers,
James
Cheers,
James
