I was looking at their AXN10 as a potential option. Slightly newer DAC in that one. Really competitive price point. Can get them refurbed for $350I’m really pleased with my setup. I had a WiiM Ultra prior. I picked up a Cambridge Dac magic 200, connected to the Wiim with usb. Beautiful dac implementation. I believe the CXN100 is their main streamer/dac.
Connecting a TV and a streamer to my hifi system is the main reason I prefer an external DAC - it allows connection to multiple source devices - via USB / coaxial S/PDIF / optical S/PDIF.I've just remembered my nice new TV has Google TV built in with the tidal app. Would it still be worth getting the WiiM? Or should I just run coax or USB out from my TV into a DAC and into my preamp?
No Tidal-Connect. That means you must either use Cambridge Audio's proprietary app to play Tidal, or the native Tidal app via (kludgey) AirPlay. Some people don't mind, but it's a deal-breaker for me.The other unit I've been considering is the Cambridge Audio AXN10
Couldn't find any info on my TV in particular. It's a Hisense U8 2024. All I know is it's got eArc, Dolby atmos, DTS-X, and digital optical audio out as well as USB out. Supposedly HDMI ports 3 and 4 can be used as outputs as wellConnecting a TV and a streamer to my hifi system is the main reason I prefer an external DAC - it allows connection to multiple source devices - via USB / coaxial S/PDIF / optical S/PDIF.
But be careful about using a TV as a music streaming source - the internal signal processing in a TV is often locked to 48kHz, because that's the native sample rate of digital broadcasting, and DVD audio, and Blu-ray audio. Also many HDMI chipsets are locked to 48kHz.
That means that 44.1kHz audio streams (which are the majority) will be sample rate converted to 48kHz before output.
I suspect that eARC/HDMI will output at 48kHz, but there's a fair chance that USB out may support native 44.1kHz.All I know is it's got eArc, Dolby atmos, DTS-X, and digital optical audio out as well as USB out.
Makes total sense to me. I'll look into the DAC first. Wouldn't hurt having one on hand even if I need the WiiM at the end of the day. Thank you for the advice you've been super helpful!I suspect that eARC/HDMI will output at 48kHz, but there's a fair chance that USB out may support native 44.1kHz.
OK, so buy the DAC first - of course I recommend the E30 II, but sure, get a DacMagic 200M if that's your preference. Importantly both options will display the incoming sample rate - if you see 44.1k, that's great, the audio is (likely) unmolested, and you have a good chance of optimal audio quality. Then there's no need to buy the WiiM. You are fully set up for Tidal.
But if all forms of output from the TV display only 48k on the DAC display, then I think it's worthwhile buying the WiiM Pro as source device.
Yes definitely.I'll look into the DAC first. Wouldn't hurt having one on hand ...
I don't think a remote is necessary in any case- your smartphone makes a remote redundant.I understand the differences with the DAC between the pro and pro plus, but strictly from a remote standpoint: do I need the remote if Im connecting to a receiver/preamp?
I suspect no, but want to double check.
FWIW, I`ve had excellent SQ, issue free use of the original Pro-ject S2 Digital DAC for over 8 yrs. via USB connected to my A/V rack`s 24/7/365 powered laptop, both the original 2009 purchased Win 10 OS one, and now connected to the Win 11 music filled replacement laptop.. I've been a little interested in the Pro-Ject S2 ultra since it seems to fit the bill pretty well.
For the sake of clarity, and for forum members whose first language is not English, I'm relatively certain that's a malaphor.If my current Pro-ject S2 ever bites the bullet
What Bill Ferris meant is that if the Pro-Ject S2 ever bites the dust.
If such a thing was to happen, then Bill, as owner, might choose to bite the bullet and spend money on a replacement unit.
I run Audirvana Studio on a dedicated MacBook Pro and I ran the original Audirvana headlessly on a Mini for a few years. Apple doesn’t allow full hog mode access anymore, but Audirvana gets close using all the processing priority allowed. Hog mode adjacent I guess. The new phone remote app is excellent. Audirvana supports internet radio, Tidal and Qobuz, AU plugins and your local library management. The software does the first MQA unfolding only, so that might not float your boat, but hi-res DSD is amazing. I switched to Qobuz anyway. I use Schiit Bifrost 4490 and Uber DACs connected via USB. Personally I don’t see the need for a streamer in my main and 2nd system. I do have a WiiM Amp in the bedroom driving NHT SuperTwo’s and it has enough power to open them up.Looking for a Tidal compatible streamer. Doesn't need any fancy features. I don't want any amplification, I've already got a preamp and power amp. A good DAC would be nice but isn't necessary. I'm willing to spend up to $800 as long as it's properly good. I've been a little interested in the Pro-Ject S2 ultra since it seems to fit the bill pretty well. But I'm interested to see what recommendations any of you might have. Any suggestions are welcome. Thank you.
