Don, on the interactions you have shared regarding your transaction, let me get this straight:
- You have purchased an older Mac amp from a seller.
- The seller represented it as being in first-class operating condition as evidenced by some level of restoration having been done to it.
- You have paid an agreed upon sum for the amp with those considerations.
- The amplifier was shipped to you in a condition that caused it to be inoperable upon receipt.
- Your own inspection, as revealed in the pictures posted here at AK, indicates that a fuse is/was completely missing. Diligence on your part has not yet revealed where this fuse has gone.
- Further inspection of the amp, including one of the potential people involved in _part_ of the restoration work, indicates that remedial work has, indeed, been done. (My observation: One capacitor with potential lethal voltages has been somewhat secured for safety but not too well and indicating low attention to detail.)
- Upon notification of the discrepancies, the seller has reacted in a less than professional manner but has indicated they would take the amp back with no other options offered.
- You have resolved to go ahead and try to power up the amp with a fuse of your own choice.
At this point, I'd suggest that you consider not doing this until you give the seller a complete chance to make things right. That is, if you power it up without full and written agreement from the seller and it fails in some way, you really will have _bought_ it. I'd suggest that you work with the seller in such a way that he remains fully responsible for the discrepancy regarding the amp's non-operational status.
I, too, have worked in customer service capacities from the vendor standpoint and the vendor of used gear in a transaction such as this _owns_ the option of repair/replace or refund your money.
I am not a lawyer so cannot speak to the details in that way, but look at your situation as if it were a used car that does not run even though the seller said it does. The seller appears to have failed to complete their part of the transaction at this point.
From a technical standpoint, that the seller did not verify the amp's operation prior to shipment is beyond me. Where, exactly, did that fuse go? Perhaps he needs to have a discussion with whomever did the last round of work on it.
Hope that helps.
Cheers,
David
