Tubby Tube
gusaudio, can you post a pic of the schematic that came with your kit and what they supplied?
You do realize that the factories are probably run by the government and so they can just offer these items with no concern for customer service.
It would be more helpful if you all supported your local craftsmen and small businesses instead of playing russian roulette with these amps.Incredibly helpful!
Pray tell, what local craftsman sells tube amp kits at this price point?It would be more helpful if you all supported your local craftsmen and small businesses instead of playing russian roulette with these amps.
Here's one that caught fire. http://www.chambonino.com/work/work5.htmlRussian roulette? Would you kindly link the thread where someone burned down their house, or wound up in an ambulance, or even threw it out in frustration?
This, and most other forums exists to HELP.
It is false economy. All the stuff you need to do to get the amp up and running. Who likes doing that? If you are upset because you got taken too, i am sorry to hear that.
Keep us posted as you build Tubby. We'll try and help along the way. I have to admit, that's a lot of parts for $200.
I agree, and that follows best practice- but in many on the net that I have seen, they did not ground the chassis to earth and the bus seems to be grounded in many places (supports) in the photos. In the build from this guy who, IIRC is connected to the kit maybe? https://drive.google.com/file/d/1_k47LjHySDs_LD-By1eDNZwIilLA-z4T/viewThat rectifier tube should be okay. There is a similar Russian equivalent which is indirectly heated, the 5U4M. Same pinouts.
You need to attach all the ground connections, including the iec ground, to a busbar, which is then only connected at the input, as on the schematic. Check the photo of this build to see the busbar. https://drive.google.com/drive/folders/1eLOxshddcliIozcab-I22yNm3IhGWbUE?usp=sharing
The only ground connection to the chassis is made via the volume control pot at the signal input.
I like that. The thin stainless chassis scares me to drill in it though. Here is what I have so far on this erector set. I added terminal strips, I want to keep it as neat and tidy as possible. View attachment 1259524You might try using a switch on the IEC socket ground? I have a phono preamp with one. Its quieter with the ground switched off. I'm guessing the switch on the ground was installed in case of ground loop problems.
