mudkicker78
Member
It was right there touching but not attached.
First off, I would like to thank you for the series of videos on the Nobsound 6p1. After watching your videos, I was curious and bought the same amp with the added headphone output.
Would I be able to do the mode using the same part list?
I just purchased one of these from ebay. It came with the rectifier tube, has a bad volume potentiometer. I also noticed the one of the 270ohm resistor the runs parallel with 220uf 50v cap is burnt. What is the size on these resitors?
Thanks
Voltages seem to be ok, I matched both left and right. One thing doesn't seem right is the heater voltage, it's reading 3.4v not 6.3v.So powered on with all tubes, no smokeVoltages seem to be ok, I matched both left and right. One thing doesn't seem right is the heater voltage, it's reading 3.4v not 6.3v.
I did proceeded to hook up to my daughter's system and a very slight thump when turned on. No output to speakers.
The meters on the front, How do they work? Do they measure the input signal?
Hello @wendell . Can you confirm what are the other voltages you are getting from the transformer.
I hooked it up straight to my kitchen wall. In my daughters bedroom it will be hooked up to an APC Line 1200. Here some voltages![]()
The heater voltages on the (2) 6SN7 along with the (4) 6p1p = 3.4VAC
The 5U4C rectifier tube heater voltage= 279.6VAC?
I measured on the tube socket pins where all the wires are soldered. So the heater voltages should be good on the 6SN7 and 6p1p.Ok. Did you measure directly on the 2 tube heater pins? Or between transformer tap and ground? Or between both transformer taps? Because I believe the transformer produces -3.3v and 3.3v which is seen as 6.6v on the heaters.
What's going on with the recitifier heater voltages? Are they suppose to be that high?
Any ideas why I'm not getting any output to speakers? I'm gonna try another source.
