I don't know what unity gain is and I'm not sure what 3db gain would be, but...
I've been using mine for a couple years now. I have it going into a Fisher 295 SS Receiver with Infinity speakers. I use it in my classroom for music and for bumping up the volume from my laptop for videos and howto's for students.
When I first started using it, it was in my office system and very nice. I did experience the microphonics, but after I bumped it while in use. Thereafter, I had no issues with it as it stayed in the same spot with the volume on the E6 set at 2-3 o'clock, pretty high. It sounded/ sounds great. No hiss. No microphonics.
The only issue I had with microphonics was when I was using it in a low to no gain line from my PC. I've always needed a gain boost from the PC so that has been accomplished for years with a Little Bear T7 preamp. When I took the Little Bear our of that line, where there had been now hiss or noise, to experiment with a clear signal just to hear the E6, the signal, apparently not being sufficient caused the issues
@StepheK and
@bridger2086 are having.
I have waited for some confirmation of this, but nothing similar has happened with anyone on this thread. The microphonics in that situation became worse when I tried to compensate for the lost gain of the Little Bear by upping the volume the E6 and then raising the receiver volume which made the ringing escalate exponentially. Lowering the volume of the E6 and trying to raise the receiver volume produced the same out of control ringing escalation.
I used the Chinese tubes out of the box without incident - other than the bump that caused ringing, but had ordered the Russian tubes to replace them in short order simply based on reputation of Russian tubes and my experiences with them in other tube pre's.
All of this said, I continue to use the unit I have and enjoy it. It sounds excellent and to my ears is very similar to the FX Audio Tube 03 with some improvement mods I've made. But the E6 is still in daily use. I would maybe suggest returning the unit and giving another a try as there does seem to be some degree of quality control issues given the feedback from others on this thread with their out of the box experience, or it could be that this unit prefers a good deal of gain to operate properly.
