allanmatters
I used a washer with the wedge heads .Good info . Any how I will buy flat head screws and give it a shot . I am guessing though the moisture has corroded the internals
Another day another experiment
Nope. Without actually running diagnostics on the gear, I can only speculate.Are you sure it's the amplifier bias circuitry or the output transistors?
In your first para Are you talking about finding another a-9 or a-7 ? Cause I already own an a-9I'd wait to see what the tech says, but it's true that you're unlikely to find a replacement transformer -- at least, outside of another A-9 -- and if you find another A-9, you've probably solved the problem another way. How much does your local rewinder charge?
Transformer rewinding is normally very expensive. On the other hand, quality amplifiers from the same era as your A-9 are relatively plentiful and inexpensive. Unless you're sentimentally attached to it, replacing the unit with something else -- ideally without obvious moisture damage, which may cause more problems in the future -- might be the best option.
I meant A-7. I saw the "Pioneer A-9 with the HMP 700's" in your sig and mistyped.In your first para Are you talking about finding another a-9 or a-7 ? Cause I already own an a-9
That's an excellent price. Transformer rewinding is never cheap, but that sounds like a bargain.So the tech called me . He says "your set is ready" I went to pick it up. He got straight to point . He said we tried and it's just fine the way it is . " Don't worry if the right heat sink is getting hot with no load. That s the way it is " . And the transformer he says rewinding of the transformer needs to be done if your really interested and that will cost me anywhere between 60 USD to 75 USD or it could go even more .
It might last forever, or it might fail in the next ten minutes.I wonder how long I have for the transformer to die out completely while I just keep using it .
Do those transistors run hot?I opened the system as I got home . I saw he has put small aluminum heat sinks for the left channel transistors on the left channel preamp board . They originally don't need a heat sink . I dint know why he put mini heatsinks on them . The transistors are NEC b861. One is green and one is black . I don't even know why he would do that .
There isn't much profit in it for him, and there's a small chance that the rewinder will declare it unfixable and you'll be left with nothing.Thanks for your prompt response. Appreciate it.
Excellent price ? If so il do it . It's just that the technician is very negative about doing it . All he has to do is disconnect the transformer and he will give it to the winding people . Once that is done he will reconnect it . Then accordingly il pay him for labour plus the 60usd or 75 USD for the new winding . He just keeps telling me " it's too risky " . He doesn't sound interested in doing the job ?
That might be nothing more than a bad solder joint, or -- perhaps at worst -- a failing semiconductor. Likely to be a relatively inexpensive repair, and you wind up with a better amp.The a-9 has a loud popping sound issue
Yes . Already made a thread here regarding that . I had suspected it was the speaker relays . But I was wrongThat might be nothing more than a bad solder joint, or -- perhaps at worst -- a failing semiconductor. Likely to be a relatively inexpensive repair, and you wind up with a better amp.
