allanmatters
double post
Replace it or live with it. It's probably water/salt damaged and windings are vibrating.So the glue did not help . I did break open the plastic housing so I could get a look at any coils if possible. Does any one know what i can do now ? Should I further open it up ?
Wow . That is something new to me. I appreciate your help on this . But will rather sell it and recover my maintenance cost s .I have had 2 Musical Fidelity A5's. They seem to come with a statuatory Toredial Transformer Buzz. Not to be confused with a Hum. The reason I have had two is. I past the first one on because of the buzzing. When I listen to say "Flameco Sketches" late at Night "Low Volume" I could hear the buzzing above the music. So I thought it was faulty - passed it on.
Year later or less I saw another for sale plugged it in. Had my Buzz back.
So I Looked into it. Found my answer on an Australian hi fi forum someone else had exactly the same issue.
Remedy: For me anyway: https://www.atlhifi.com/shop/fully-assembled-devices/dc-blocker-trap-filter-assembled-in-case/
Stop the buzzing dead no sound comes out of the case Absoloutly brilliant Brilliant : But Expensive
Probably no effect -- other than running the amplifier circuitry on slightly higher voltage than normal -- unless the loose winding(s) that's causing the hum is on the 240v tap.There's one more thing I do not mind trying .
Since my amplifier has 110v 120v 220v and 240v as a selector behind . (Currently and it's always been on 240). Will it make a difference if I switch the selector from 240v to 220v ?
I am getting about 235volts . I checked this with a volt meter .
So is it worth a try ?Probably no effect -- other than running the amplifier circuitry on slightly higher voltage than normal -- unless the loose winding(s) that's causing the hum is on the 240v tap.
It's unlikely to hurt. You will be running the unit internally at slightly higher voltage than before, which might be enough to pop some marginal component.So is it worth a try ?
