Noisy Tube Rectifiers :(
It's funny, but building a dead silent amp was always my top concern. Of course I would be disappointed when I shoe horned my ear into the throat of a 511B and could here a slight hiss or hum. Tom B. made a post once about how currents move through and around on a chassis and somehow it stuck. I haven't had a noisy amp since and finally quit worrying about a tiny hum or his that you had to get out of your chair to hear. Nowadays I pretty much star ground everything. It makes for a busy circuit with tons of wire, and takes quite a bit of time, but I think it;s worth it.
ive never heard of this problem before but then again ive always run old american made tubes. interesting things you learn on this board.
Yeah it's likely just a cheaply made tube. The amp's output is silent with no hiss or buzz, just a very slight hum if you put your ear a couple inches away from the woofer. This sound is purly mechanical in nature and likely the filaments vibrating or something like that. I will go get some cheap diodes tomorrow to try SS and see how I like it. Thx for all the comments so far!
UPDATE: I swapped in some diodes and it's quiet as a mouse now, actually even quieter. I did reduce the HV taps to 350 0 350 from 400 0 400 and I seem to be getting the same B+ voltage, so that is fine. I also installed a 30 second delay relay to give the tubes a few seconds of warmup before the B+ is applied.
Sound? Well, I have to experiment a little more, but it does seem a little more dynamic and detailed at the expense of being a tad more edgy in the highs. Maybe it's just the cheap 1N4007's I'm using. I am still going to experiment with tube recrifiers though, I made it very easy to swap between the two.
I have ran a few of the RCA 5u4's with great results. I am running one now in my Latino ST120 and it has been rock solid.(much better than the newer gz34's)
I also have a CBS 5u4 that I got from Jim McShane. Another very good 5u4!!
I could not think that you would have any problems finding a good 5u4.
-Vic
Me too! No problems with the 5U4's many with the GZ34's!:thmbsp:
Hey Vincei,
Have you "rectified" your issues yet with your rectifier tube yet? Any more experiements with the SS rectification? So, what do you think?
Since I posted last in this thread, I have installed a Weber Copper Cap.
The WZ68. It is equal to having 2 GZ34's in the amp.
Wow, what a difference all around!!! for the BETTER.
If all else fails, this, IMO, is a good option.
-Vic
Get yourself some nice Hexfreds from AES, or if money is no object, get some Cree from Parts Connection. There's nothing better out there yet.
