Bob_in_OKC
Addicted Member
It seems like if you understand logical fallacies so well, you'd reconsider what you've written thus far.
I wasn't trying to sell anything or get personal...no affiliation with KAB.
they would be of the most importance.
http://www.kabusa.com/myth4.htm
They publish weighted and unweighted.
The same method used to verify manufacturing equipment specs, the machines used to build heart valves and aircraft components.
The two seem mutually exclusive.![]()
No vinyl I've ever heard is perfectly dead quiet anyway. There is always some rumble, "whoosh," crackle, or tape hiss introduced at the time of cutting or pressing, anyway.
If dead quiet is what you are after, you may spend thousands, and still not achieve it... unless you are buying a CD player.
[/QUAfter reading the tech specs of the Technics, I wondered if all those much more expensive belt driven turntables can really beat these numbers.OTE]
its a test you can do yourself to see how important these figures really are..
tap the plinth of a technics (or any other) direct drive turntable while its playing and then do the same with a relatively cheap belt driven philips ga-212.
Which one sounds louder through the speakers ?
the repeat the test by tapping the surface the turntable sits on...
then repeat the test by letting the cartridge play for a minute or two in the run out groove on both decks whilst listening for hum and mechanical vibration within the turntable itself...
another good test is to place a turntable on top of a speaker with a decent sized woofer ...crank the speakers with some bass heavy music and listen to see how effective your turntable is at filtering out external vibrations![]()
:thmbsp: I can knock on my table while it is playing, and not a single bit finds the speakers........I give that demo all the time. God bless Ed Villchur.
I know this is an audiophile sin punishable by death, but since I lack the rack space, my SL-Q3 has been being operated directly on top of one of my JBL L-71 Verona speakers, (3-way, with a 15" woofer,) while doing some experimentation with other TT's over the last couple of months. Only at the highest of ear-bleed volumes do I notice a little bloat, followed by a quickly-decaying trail of rumble after high level passages. I'm fairly impressed by it, actually.
I have a Philips GA-212 as well, and it has a great tone and low noise floor but I'm not thrilled with it's speed stability. I would imagine (hope) it's wow and flutter performance is supposed to be better than mine is delivering. When compared to my DD's, it's speed variance is definitely audible. Perhaps I need to go through it and clean some pots, maybe even consider a re-cap. But I digress...
The Philips' interconnect cables are too short to make it over to my speaker, so I can't compare. However, it seems far more sensitive to lateral shock, such as shutting a rack door, than my Technics decks.
Fully agree :yes:...the rega, however, uses a different design approach to a typical direct drive or 3 point suspended in how its plinth deals with vibration.Try the same test with a Rega or Pro-Ject belt-drive deck instead of a suspended turntable such as a Philips or an AR.
