Is the pop coming from both speakers, or just one?
Common issues with pops I've come across were caused by various issues.
It can be cauaed by failing capacitor, a failing rectifier, driver or power tube, and even from cold or cracked solder joints.
In one of my amps it was the voltage gain driver tube failing. One section of the dual triode was having intermittent shorts and arcing. I even saw a flash happen inside that tube.
In one of my mono blocks I would get intermittent pops mostly at start up. It took me awhile to find the problem until one day I saw a small flash through a vent slot on top of the amp. It turned out to be a crack in a star ground solder joint. I didn't notice it before even with a magnifier. With the bottom off and lights out I turned the amp on with the bottom off and saw the small arc.
In yet another amp it was the power tube arcing internally.
The tubes that were failing caused a pop in one channel only, where as the bad ground solder joint caused a pop in both channels.
It could be a failing cap too though, or maybe even a bad resistor.
