OMGCat!
The other day I found a non-working M60 locally for a very good price (almost free). It looked kind of beat up so I figured it would probably have one smoked channel which would make it a good parts amp as I have an M60 and M65 already.
I got it home, hooked it to a DBT and found it's in protection but the bulb dims normally. I found that someone had done previous repairs to the rectifier board and attempted to wire wrap by hand which resulted in a whole bunch of loose connections.
The main board was absolutely coated in dried soda or some other thick sticky substance.
I could have left it at the and parted it but I figure all the parts are better together and if I can get the amp working then I know I have all good parts. Beside parts I will have another M60 so maybe I can vertically bi-amp my speakers, blah blah, you know the deal already.
Work so far:
Cleaned boards with simple green and flux brush to remove sticky stuff. This took about 45 minutes of brushing but the boards look darn near new.
I repaired the wiring on the power supply.
Removed DSBG and replace three jumpers. I put the old 1000uf caps back even though they are showing around 750uf. If I get it up and running I'll recap it later.
I removed the open frame bias pots due to soda intrusion and found the right channel pot to be showing 1k rather than the usual 500k that these seem to hover around.
I replaced both bias pots.
After that I attempted to power it up and it still won't come out of protection but again, the DBT dims and goes out.
I checked the transistors lined up on the heat sink and found 1 2SA1306 to be shorted on the right channel. Not it's counter part and none of the outputs are showing a short.
Would the low value of the bias pot cause this one transistor to short? What else should I be looking for? I was planning on following along on one of the M60 Chernobyl threads but mine seems to have decided to fail in a new, novel fashion.
I do have the factory manual here so can follow the schematic but thought I might get some input from the experts.
I've ordered replacement transistors from Digikey 2SA1837 and 2SC4793 and am out of town for a few days starting tomorrow but thought I'd get my thoughts primed for what to do when I get back.
Also, aside from the few watts and the ability to shut off the meters, what is the difference between the M60 and M65? They look identical inside.
Work so far:
