OMGCat!
UPDATE:
I got my order so replaced the rest of the zeners, brought it up and no dice.
Taking voltage measurements I found that a lot of the points had higher than the high rail voltage so I checked the schematic and found the HB+/- is 60v.
Why not desolder the leads (there's a two pin connector going in by the Auto A stuff) and see what happens?
I powered it up on the DBT and it came out of protection. I jumped when relay closed because I thought something had popped, ha.
So, with the HB leads disconnected the amp is powered up and out of protection. Now I just need to see what the heck is shorted causing the HB+ voltage to go all over the place.
