dogwan
Dogwan
I've seen quite a few videos now on YouTube (including GR Research's) where it's stated over and over how bad it is that manufacturers ruin perfectly good non-ferrous binding posts by using Steel nuts and/or other hardware.
My question is... how bad is it really?
What are the actual consequences?
And at what point do you start to notice?
We see so many vintage speakers and even modern ones where this seems to be the norm. Plus, I keep finding that even Parts Express modern commodity grade caps and resistors intended for speaker work actually have magnetic leads. Whenever I pick up a set of vintage speaks with old spring clips (even the high-end ones from years past) I pretty much automatically replace them with 5-ways. But I don't usually spend big bucks unless they are serious keepers. Which means even the semi-decent 5-ways from Mouser intended for test and instrument equipment comes with gold plated steel nuts and lock-washers. Lately I've started running down to the hardware store and picking up Brass nuts and Bronze lock-washers. I don't mind really. But starting to question my sanity.
What say you all?
What say you all?
