You seem to like Technics, have you had any trouble with them? I have just returned an SP-Q3 that I purchased from eBay because it was doing weird things like lifting, going to the start of the record then returning to the armrest, sometimes it just lifted and went down again, sometimes it would work okay. To be honest it has put me off technics turntables after looking on youtube and seeing others with the same problems.Thorens TD-224
Technics SL-1200 MK4
Technics SL-1200 GAE
Technics SP-15
Technics SP-10 MKII
Technics SP-10 MK2A (NIB)
Technics SP-10 MK3 (x3)
Victor TT-101
Kenwood L-07D
Sony PS-X9
Nakamichi TX-1000
Denon DP-100
He could rent them out so he could afford a new one.
Technics ran the gamut. Made what some consider the best 'table on earth as well as some very economical pieces. After 30+ years the problematic ones are rather well known so a bit of research pays off.
Old list. SP-10MK3 count is now 5, and I've added an SP-10R.![]()
They asked who had the most, not who has all the best tables!![]()
Sorry, yes you are right sl-q3, I liked the look of it and if this had been just one isolated problem I would have taken time to find and fix it but as I said I looked on the internet for answers and found other owners having similar problems with this and other turntables in this range from Technics, most of which were unsolved, this could have been a fault with the electronics and apart from cleaning contacts and a visual check I have no way of testing these, mechanically everything seemed to be working as it should and at times the turntable functioned properly but then it would start to play up again so I returned it.I’m guessing you mean the SL-Q3? My impression is that Technics is more reliable than average rather than less. Certainly if the seller represented it as working correctly when it does not you should return it or negotiate a different price if you want to try to fix it.
