old Lafayette
fanis
Hi, i got two old Lafayette SK-130, 15 watts, 16 ohms, i am planning to use them with tube amp.
I want to know if it`s a good match and i want to make some cabinets, all info will be very appreciated.
Thanks!
I'm pretty sure the SK-130 is made by Goodmans and rebadged for Lafayette. I've got quite a bit of Goodmans driver info so if you post a photo, I'll see if I have the datasheet for that model.
They do generally make a good match for a low powered tube amp due to the 16 ohm impedance and high efficiency.
