I am trying to determine which caps in a Harman Kardon TD202 cassette deck are low noise/low leakage caps. The deck currently has a mix of TK and Panasonic e-caps which I believe are original from the early to mid 1980s. Unlike other service manuals, the SM for this unit does not indicate any of the e-caps as LL/LN, but I would be surprised if the deck doesn't have any. In my limited experience, the LL/LN caps usually have an orange or yellow sleeve. Not so in this unit. All the caps have some shade of blue sleeves. I observed that there is a difference in polarity markings of some of the Panasonic caps connected to the Dolby chip, making me think that Panasonic at that time used that difference to designate their LL/LN e-caps from their standard e-caps. Attached is a picture that shows the two different types of polarity markings as shown on the caps in the blue circle. The cap on the right is rated at 0.68 uf/50v and the left is rated at 2.2 uf/50V. I am assuming that the cap on the right is a LL/LN cap and that Panasonic used that style of polarity markings to designate their LL/LN e-caps. There are 4 other caps in the photo with polarity markings similar to the right cap. The others are (3) 0.68 uf/50V and (1) 1uf/50V and are associated with the Dolby circuit. These 5 e-caps are the only ones in the unit with this style of polarity marking. Can someone verify my assumption regarding the style of polarity marking on the right cap designating a LN/LL e-cap?
Thanks
Thanks
