Yeah that picture is actually one of the better ones , today there the lowest of the low crap some even say there party system or are 700w rms yeah right . Wattage does not make quality .
These aren't MDF, just particle board (and probably pretty lightweight particle board at that). You could probably mix up a sawdust/wood glue compound to fill the space, but I probably wouldn't use Gorilla glue since it expands during curing.
Thanks I don’t understand what’s up with all the speaker bashing , these are good quality for the type of shelf speaker they are . And I want to practice repair on them before moving on to my bigger ,! Nicer RtRFirst, the Gorilla Glue Clear does not expand, or foam, or any of the other fun things the Brown version does. And OK, if'n ya wanna be picky-pants maybe it is particle board and not MDF... So.... Did you have a point that is material to the discussion, or are you just the nomenclature police? Both are crap materials to use for frankly anything, except, geesh, they sometimes have useful damping characteristics not found in board-foot lumber and are uniformly isotropic in their mechanical properties whereas board-foot lumber definitely has differing mechanical properties with, across, and through the grain, and even that depends on which cut technique was used and what part of the logs your boards came from. I don't like MDF or particle board, but there's a bunch of vintage and new cabinets made up of materials that are essentially a cured mixture of 'glue' and wood 'pieces' (I don't want to debate resin vs glue, vs plastic, vs elastomer, vs epoxy... or slivers vs. chips, vs sawdust vs splinters vs shavings, vs curlings, vs... ad infinitum). BUT none of that really matters in this context. We have the cabinets we have. Most use some form of this crap material. Fix yours or don't... The OP asked for a repair method. I have actually repaired damage consistent with his dilemma, so I chimed in. The repair process described works with any of the typical materials that could be described as a cured mixture of 'glue' and wood 'pieces'. If you have repaired similar with lasting and functional results, please post your method. Otherwise...
I never said these were top of line speakers or anything, obv there old and discontinued.
So wood peices and what gorilla wood glue ? I tried a different brand of wood glue when making my diy subwoofers box and the brand sucked . Wish I remember the brand !!
GChief, I'm not clamping anything, just trying to stabilize and hold together what remaining material may be present. First you have to stop the spread of the damage and the loss of little pieces by using glue. The glue is like encasing the wood in lucite. Slather the glue on and use your gloved finger to spread it out. It seeps into the material, bonding the first 1/8 inch or so together, hard as a rock. I am assuming the cabinet is water damaged, weak, decaying, with local breaks or cracks, and with broken corners, but generally intact, and in the shape of a speaker cabinet. If you have assembly joints that have failed, see my comment about pulling glue into the joints with vacuum applied to the inside of the cabinet.
You kinda need to give it a try and see what happens...
No bashing from me. Learning is good and these will give some practice on material that will be challenging. If you can make your repairs so they blend, and are difficult to see then you'll know you succeeded. Tightbond carpenters glue is good. On these I would use some sort of bondo type filler, then sand and paint spots to match. You can be creative as you wish - auto parts places have a lot of shades of spray paint under the duplicolor brand. You might find a very close match.Thanks I don’t understand what’s up with all the speaker bashing , these are good quality for the type of shelf speaker they are . And I want to practice repair on them before moving on to my bigger ,! Nicer RtR
Often these type of systems are teens first introduction to decent sounding stereos, which gets the buds unplugged out of their ears! This is a win-win! Hopefully it will inspire them to take the next steps up the sonic quality ladder and get more serious about the sound from a good system.Yeah that picture is actually one of the better ones , today there the lowest of the low crap some even say there party system or are 700w rms yeah right . Wattage does not make quality .
These were a fad but some brands still make them , blue tooth speakers are the new shelf system .
I guess there for impulse buyers .
Yeah I still have my first one of these it was a pro logic surround system , but it’s more of a stereo for bass heavy music . I’m trying to decide if I want to flared port my Rtr or re seal them ? Are they acoustics suspension??Often these type of systems are teens first introduction to decent sounding stereos, which gets the buds unplugged out of their ears! This is a win-win! Hopefully it will inspire them to take the next steps up the sonic quality ladder and get more serious about the sound from a good system.
.Not just any wood filler. Use the Bondo or Minwax I mentioned. It is a 2-part epoxy-like putty. You mix it, fill the damaged area and it hardens. It is easy to sand and finish.Oh wood filler ? F
