MikeCh
Those JBL L96's turned out really super, Mike. Congratulations on a fine job and a really great writeup too! It's very encouraging and inspiring to see what you've done.
I do have one question. When you trim the veneer after having applied it to the cabinet, you mentioned leaving an 1/16" overhang for sanding later. So, when you apply the next sheet of veneer, I expect you then align the sheet flush to the edge of the previously applied sheet. However, doesn't this present a problem for the bottom sheet of veneer applied? Judging from your tutorial, you did side-->top-->side-->bottom. But the bottom will be restricted from fitting fully due to the 1/16" overhang from the two sides. Do you trim one side a little more so that the bottom will be able to overhang on one side?
Hi Gary, thank you for the kind words.
You know, I've been asked the same thing from several AK'ers, both in this thread and in PM's about the process of leaving the little overhang + getting the next sheet in the process to align properly. It's been a little while since I've veneered a speaker cabinet (at the time I wrote the tutorial, I had done five or six pairs of speakers and it was fresh in my mind as to the process). I believe the reason the 1/16" overhang worked out ok for me was the fact that the original cabinet material/underlayment that the new veneer was applied to was not exactly, perfectly 90 degrees square between faces. This due to sanding the original veneer/cabinets down without exact precision.
Basically, the once factory 90 degree face intersections of the original cabinet became a little forgiving if you will with the placement and subsequent 1/16" overhang of the new veneer. This allowed placement of the new sheets without crushing the little overhang and resulted in the ability to sand the little overhangs to allow a nice joint in the end.
By all means, if the 1/16" overhang bothers some, just trim each newly affixed veneer face flush and lay down the next piece doing the same as you work your way around the cabinet. Just be careful that you don't accidentally trim beyond flush and inadvertently create a corner seam that doesn't meet up well. Post #65 & #69 in this thread might help to explain it too.....
Best,
Mike
