Onkyo Integra 927 Integrated Amplifier!
jblkef92
Just picked one of these up. It is a 100 watt, Japanese import amplifier with a champagne faceplate and solid wood cabinet. Aside from that, this is all I know. What are your thoughts?
index.php
Don’t know a thing about it but I like what I see.
Definitely let us know your listening impressions when you get it set up, I bet it will be excellent.
That looks like the one yep! I'll keep you guys updated let you know how it sounds. If anyone else knows anything or has had one, do share your experience.
Onkyo A-927 is Japanese model designation, European/US model is A-9911.
A-9911 might be slightly different (specs wise) than A-927.
Details below:
Specifications
Power output: 90 watts per channel into 8Ω (stereo)
Frequency response: 2Hz to 50kHz
Total harmonic distortion: 0.06%
Damping factor: 130
Input sensitivity: 0.3mV (MC), 3mV (MM), 300mV (line)
Signal to noise ratio: 70dB (MC), 87dB (MM), 105dB (line)
Output: 300mV (line)
Dimensions: 435 x 165 x 444mm
Weight: 19.7kg
