The fellow who bought my pair, the same exact thing happened, and the sound was also terrible. He is the one whom had the luck with the vacuum method, and yes afterward the shape had returned and the coil rub ceased. It takes a delicate hand with the wand, applying a closer angle just ‘til it pops. This is done with the little protective grille in place, but mostly taped up to concentrate suction. Your hand and attention makes it work or not work. It is a precision type of job.
The screens are set in resin, Onkyo Japan uses heat to remove it all, and then supplies a new screen set in resin again. If a typical end user forces them out, then there’s little hope that they will get it to seat again.
The mids are finished with a very fragile bonded ceramic-diamond coating, strong tape will likely remove it. Suction through the screen will not. Or at least it did not in the case of the above mentioned job. I saw the after, you could not see so much as a crease without a glass.
