foxbyrd
Hey there,
I recently acquired an Onkyo TA-R22 stereo tape deck at an estate sale. It seemed to be in working condition -- however when I plugged it in and gave it a listen, there was a pretty enormous audio quality issue. I figured it was likely the heads and pinch rollers that needed cleaning, so I removed all the gunk from those pieces, yet when I attempted to give it another spin the issue remained the same.
Basically, everything sounds remarkably muffled, there are sporadic crackling noises in the center channel, and it's only playing back in mono. I popped open the lid to see if there was any noticeable issues, but my typical solution for restoring stereo audio on older decks (cleaning the play/record switch with deoxit) seems to be moot as there isn't the long narrow switch internally. Dolby B & C are unusably muddy, and without them it sounds unbearably tinny/strident/sibilant.
I would greatly appreciate advice or help on how to resolve these problems from individuals way more experienced than my dilettante self. Thank you
