You can go up a bit in capacitance (10% or so) and up in voltage by even a bit more (20-30%).I want to replace the power supply caps on my Onkyo TX-1500 MKll.
Current installed caps are Marcon CE62W-C 47oouF 35WV.
Have a hard time locating a replacement for them. Anyone have a idea were I can get replacements?
here's a novel thought: buy new brackets.If you have a bracket that holds the caps in place you may try to get as close as you can to the diameter of the stock caps. If the new caps are still too small you may have to devise a shim to be able to use the newer parts.
