I set up my Onkyo TX-8020 earlier today. I was not able to connect the FM antenna that came in the box with the unit, however. The antenna uses a connection I am unfamiliar with. It appears to be similar to a coaxial cable such as the kind found on a TV antenna or a internet modem. I used a dipole antenna with my previous stereo receiver that had two metal prongs that you would screw tight on to the receiver. I can not figure out how to connect this type of antenna. Does the end just push on, or am I just stupid? Any help would be appreciated!
