DanWentworth
This venerable old receiver recently started going into protection mode.
The obvious damage was to R41 ( 5W 0.47Ohm cement by Micron 77).
After reading the post by Jon_Logan, goat67 and str8tlk http://audiokarma.org/forums/index.php?threads/onkyo-tx-8500-trouble.223285/page-5
I determined that Q14 is also toast.
With the Outputs (Q12,Q13,Q14 and Q15) removed I measured the B1 to B2 Voltage (1.136 Vdc) as well as B1 to ground (0.69Vdc)
R29 (47ohm 1Watt) has discoloration and is a candidate for replacement..
The plan is to replace
- The Output Transistors with ON Semi MJ21193\94's (Q12,Q13,Q14 and Q15)
- The Collector and Emmiter Resistors (R39toR46) (0.47Ohm 5Watt Cement, 0.33Ohm 3Watt Cement)
- (R29 and R30)
I am running into a difficult time sourcing the Collector and Emitter resistors. (Currently Micron 77), I have been unable to find specs for these.
Sticking with the same form factor:
My gut tells me that the Collector needs to have the same specs as the Emitter I am seeing temperature coefficients from 600ppm and -80--25ppm.
I welcome any advice\suggestions particularly regarding the Collector and Emitter resistors.
Dan
- (R29 and R30)
Dan
