Quite a while ago, and on EW's recommendation I upgraded the OP amps in my AU-D11 II from the original M5219L SIL-8 package OP amps to OPA2604 PDIP-8 OP amps. This was only possible because of the excellent 'Brown Dog' PCB adapters made by Cimarron Technology ( https://www.cimarrontechnology.com/ ) (no afil'). Using them meant you could easily replace the above for a very worthwhile improvement in SQ and offset stability.
Move forward a couple of years and I discover the OPA2604 PDIP-8 package OP amp has been discontinued and is NLA. After a bit of research I found out that the reason it had been discontinued was that its performance couldn't be guaranteed with the supply voltage close to its published limit of +/-24V because of heat output and package dissipation concerns (these OP amps in the AU-D11 II do get warm). I couldn't have my beloved AU-D11 II's future existence in doubt because of running hot OP amps that are obsolete. So I began to research a solution that would resolve this problem.
The OPA2604 was chosen because it has FET inputs and was one of the very few OP amps that would operate with up to a +/-24V supply, most others being +/-18V or lower. The supply provided in the AU-D11 II being ~ +/-21.5V meant they were even being under-run a little. So, I hear you say, why not tweak that supply and bring it down to +/-18V to expand the available OP amp choices? The problem is that the supply is not just for the OP amps, but it also supplies the associated bipolar transistor circuitry as well. There were also concerns that the SQ from the OP amp might be affected by a lower supply voltage. So as far as I could see the effect of doing this would be significant, and not something I would like to even try.
I discovered that the SOIC-8 package OPA2604 is still available in very limited quantities, but also the single channel version of the same OP Amp the OPA604 is freely available in SOIC-8 or PDIP-8 - result! - To the rescue comes Cimarron again - with their dual SOIC-8/PDIP-8 single channel OP amp to SIL-8 converter - and we have problem solved. The single versions of the OP amp can shed enough heat for there to be no performance issues. Thus replacement is a simple job, I already have the OP amps and the Brown Dog adapters to make the conversion, and have made up one of the Brown Dog adapters with 2 (single channel) OPA604AP's in PDIP-8.
Update 2022
The PDIP-8 OPA604AP is becoming obsolete, so need to use the SOIC-8 OPA604AU with appropriate Brown Dog adapter. (https://www.cimarrontechnology.com/product/browndog-040701-sil-single-to-dual-op-amp-adapter)
I'll update here after I have changed them.
Update 2022
