The advantages of buying raw drivers vs complete speakers is they cost less and take up less space which makes them easier to hide.
So true! I'm building a shelf in the garage to stash all my drivers that are not in service. Keeps them out of the way, and keeps them safe. It buys me at least a few weeks before anyone finds out I've added to my stash.
Doing my research on those Maggie (Rola, cleveland, jensen, etc) organ speakers, I found that some of them came in pairs with a ribbed cone for lower frequency and a smooth cone for mid/high frequency. Then, I also found that some of the ribbed cones did service as a full ranger. I guess we will find out. But those ribbed cones sure look a lot like those good Zeniths...
G'day all,
Any opinions on the material or panel thickness of your beloved OBs? Don't think MJK references to this.
FB
I'm no expert, But I've found that 3/4 worked best for me. Easy to source, easy to work with, and cheap. I spent hours researching and realized I was just trying to find a better way to make a flat board with a hole in it. Grab a flat board cut a hole in it and see if you like it. if you do, and I hope you do, then you can source a nice piece of birch ply, and build something that looks more presentable. The great thing about OB, is you can be up and running in a matter of hours. I built the JE labs baffles with some crappy scrap plywood lying the back yard, 10" RCA alnico drivers from 1957 and lived with them for about a year because I couldn't stand turning them off. They can be THAT good.
I'm now running H frame open baffles. I'm starting to experiment with bracing my h frames to help remove the resonance from the woofers being transferred to the top baffle. I'm also planning to make a sand top filled baffle as well. You can take these as far you'd like. Its probably at the point of diminishing returns now. But to me, tweaking and playing with them is almost as fun as listening to them.
Feel free to PM me if you have any more questions, I'll help where I can. Poultrygeist is also a great source of info around here and is one of our resident OB preachers, and in my experience, is happy to help.
