Poultrygeist
Lunatic Member
I had these OB Tektons on long term loan and had lots of fun with them. The little Fostexs were so detailed but without the H-frames there wasn't enough meat on the bone. Eric at Tekton sells dual subs for these OB's.
That's what I thought...that it was a compression driver. CDs can be dipolar? If it's a compression driver doesn't that mean the magnet covers up the back-side of the diaphragm? I thought cd's by design had a magnet as the entire rear structure of the driver assembly.
So here's my "final" baffle mockup. Before I commit router to wood, can anybody see anything I should do *different*?
Here is a close up pic of the back of the coax speaker with the Radian diaphragm visible. Sorry for the pic, the ambient light sort of fuzzed things out.
Here is a pic that's a bit better, and you can see how the back of the co ax driver is arranged.
Regards
Mister Pig
Don't think it'll be as pretty as what you've got there though. I had just spotted your Hawthorne thread in the last couple days. Very nice....everything is designed to come off with a little pressure. All guys know this; it is in our genes
Well how 'bout that...here I've been thinking all along cd's can't propagate a rear wave (clearly this noob still has plenty to learn). I took at look at my Radian 475PB's and the back cover is plastic. I peeked under the emblem/model badge on the back and it's solid. But it looks like your's is the same as mine, but with a hole. I wonder if I could get an open back cover plate like yours from Radian? :scratch2:
This will change the sound of the compression driver that would need to be accounted for unless crossed over quite high, 3-4x fs, at a guess.
There is a screen across the opening, and it is held in place by a large o-ring.
Regards
Mister Pig
The screen covering the Ti tweeter in my L100t's was secured the same way. Clever, but kind of a PITA to get on and off.
Buy yourself an extra set of backs, cut them open and experiment and see what you like. You will have a bit of a chance in experimenting with crossover points if you want. I have listened to both arrangements, and prefer the dipole back. Yes the speaker is a bit softer, but when I weigh all the positives and negatives, well I take the dipole arrangement. All in all it is a pretty cheap endeavor, and then you know.
Regards
Mister Pig
