Poultrygeist
Lunatic Member
If you want to taste a bit of the OB experience take your best box speakers outside and listen to them in near field with your back against the house. The openness and airy sensation you get from OB's is similar.
Cause when it comes to OB's I can't shut up.
Here's a thread on the storage cube H-frames:
http://www.audiocircle.com/index.php?topic=119359.msg1255174#msg1255174
This project will use two 10" woofers for the bass section with each cube supporting a single driver. It should be noted that the smallest cube will house most 8" and 10" drivers; the largest cube will accommodate most 12" drivers.
So...what should I be looking to do with my Coral Beta 8 drivers? They're in traditional cabinets, only mine aren't ported, but have a passive radiator in each. I do have dish pack cardboard though, so I guess it's time to experiment. Any baffle size recommendations? Been trying to read up on it but still haven't gotten it all down.
You see examples of single drivers in open baffles like big Altecs but few can go it alone. It makes all the difference in the world to add pro woofers to open baffles.
poultry
maybe you could do a sticky on OB designs; might help w/ all these questions
Last night I extended the width of my baffles using rigid fiberglass panels.
My baffles are now about 4' wide and 4' high with the drivers at ear level.
The speakers now go very deep.
No measurements (no mike...)
I'm a happy camper.
Just keeps getting better.
I'm still playing with baffle size and design.
Am now thinking about a modular design for extending the baffle width rather than using the hinged approach which seems so popular.
This would allow one to build the very wide baffles required for deep bass and not have the speakers occupy the entire room when not in use.
I'm using vintage University 312 Series 200 diffaxials.
Art
That's great. I felt the same way when I built the big folding wing Betsy's. I thought I had decent bass and was satisfied or at least thought I was satisfied.
If I hadn't discovered OB pro woofers I'd still be happy listening to the folding wings. But the difference is night and day. Wait till opa1 gives us a report on his Alpha H-frames. He's already loving the Wolverine tops and that's just half the project.
Honestly, how much back space is needed on an OB to make them work right?
I have followed this thread with interest and haven't felt the urge to build a speaker this much since I did my OLA E-Waves years ago.
If you don't have a preamp with two outputs, connecting these to the CD player/source can feed the amp driving the FR speakers as well as the amp driving the woofers.
Using these splitters, the signal is stronger than from my dual output preamps.
