And could you give me a hand getting this hooked up. The 275 on the 15's and a SET on the other driver. I suppose I need some kind of crossover
While reading and deciphering would it make sense to use a 6" fullrange above the Alpha 15 instead of a 15" such as the Super Alinco 15. In other words do I need two 15 inchers. My room is 17x26. Sorry for all the questions
I've found that turning ON the LOUDNESS adds just enough bass that my OBs sound good without using the subwoofer.Betsy's and run a sub. Or the AN15 and maybe not need the sub. The Betsy's can have a smaller baffle if a sub is used. The AN15 and large baffle would make the grand statement. Good luck.
Yes this does work. But with a passive sub it sounds cleaner in the lower midrange. I tried a tube amp with the Lorenz and the sub. Sounded real nice. I have to work on the tube amp to finalize the setup. The Betsy's with the STA 2100d and loudness worked also.I've found that turning ON the LOUDNESS adds just enough bass that my OBs sound good without using the subwoofer.
Those fmods look interesting but haven't got a clue how to bi amp to speakers in one baffle. Think I may start out simple and use just a full ranger to start and do some serious investigation.
The Fmods ( or any active crossover ) would go upstream of the amp:
Source > preamp > Y cables > full range amp > full range speakers
Y cables > Fmods > woofer amp > woofers
If you don't have a preamp you can come off the source with Y cables and feed both amps. The Fmods would then go on the input of the woofer amp.
It hadn't occurred to me to consider a "passive" sub. Hmmm... something new to try!
So I need an active crossover if running full rangers & Alpha 15's?
