Hello AudioKarma Members,
I've recently broke out the record collection and tuned up the Dual 1216 turntable. Pick up a new Emotiva TA-100 to power it. Unfortunately, the current Onkyo speakers do not do it justice. So I went looking for replacement loudspeakers.
I was recently given a pair of Optimus 1B speakers. They where in storage for an extended time, but appeared to be in good condition. Cabinets (walnut veneer) are solid and the drivers are visually in good shape and move freely. Yeah! The plan was to upgrade the crossovers and replace tweeters. However, when got them home they produced no sound. I removed a woofer to test with an Ohmmeter and it appears the voice coil may have grounded. So, I'm looking for a little guidance. Are voice coils available for this model? I'm sure a professional could repair them, but are they worth it? If I save these cabinets and replace the drivers what are your recommendations? My budget is $300-400. Thank you.
Optimus-1B Oiled Walnut Speaker System
(400-2005) Specifications Faxback Doc. # 32001
Frequency Response:.........................................20 Hz to 20 kHz
Power Capacity:......................................45 Watts (Music Power)
Speaker Complement:..........................10 Inch high-compliance woofer
.........................Two extended range high-compliance 3 inch tweeters
Enclosure:..................Sealed oiled walnut for extended bass response.
Removable grille.
Control:...............................................Tweeter level switch
Dimensions (HWD):.......................................23" x 12" x 11 1/2"
Removable grille.
