andersonpaul
Member
RS woofer problem
Sir: Gentle suggestion... try this: turn your bass tone control all the way down while listening to natural sound...voice and music. Listen to it for about a half-hour.If your setup no longer offers tone controls, then please find one that does, and then proceed.. You may have discovered that in a way everything sounds much better. The problem is that the benefits of open baffles or dipoles apply pretty much to frequencies 300-500 hz and below. My Spendor BC1 s and in fact all of my many box speakers have trouble in that range...so much so that the only practical solution for me was to turn the bass knob down so that the honk and hoot at those frequencies no longer annoyed me. A little thin? of course. But I could deal with that .I listen currently to my old DQ-10 s for reasons of space. The box effect is least bothersome to me with these than any of the other box speakers I still own. This suggestion is as an experiment only...intended to help you nail-down the problem you seem to have with the RS boxes.........I still crank the bass down with the DQ 10s as needed.........usually for speech and vocals. When I can't stand it any more on music, I switch over to BIG full-range tympanis and ESL s. As an experiment once, I substituted a number of tweeters-some still in the boxes, for the dead esl JansZen tweet in one of my KLH Nines. Hardly noticed the difference. Whether the tweeter is mounted in free-air and radiates in a dipole pattern or not is of relatively small sonic consequence. Lower mid and bass matters a lot. A whole lot. The JansZen module ESL boxes sound glorious.... box or no. The little RS woof is unhappy in its box at exactly those frequencies that you find musically troublesome. So long as you try to make it sound happy in that range by swapping tweeters and caps and so-on when the problem lies elsewhere, in my estimation, is a use of your time best spent by seeking--out an eq tool that can tame the hoot, or to find a new home for the RS and keep trying. Find any old planar or open-baffle setup and see if your tastes run along those lines. It sounds to me that you just might be sensitive to box hoot. Good luck, Paul (first stereo in 1958....been around the block.)
