ttbccw
Ok. The one bad one that doesn't make sense is R649. All the others are on the power amp board around the driver transistors. And looks like both L & R channels. Which is odd.
Test the voltage at test points K709 & K708 (POS and neg from the big caps)
Might be a good idea to check the output transistors and all the driver transistors on that board ... starting with the differential pair Q501 & Q502. Those regulate the DC offset. The 5606 was upgraded with an adjustment for it.
